Einleitung
This guide will show you how to replace the motherboard on a Nokia Lumia 930 smartphone.
Was du brauchst
Pull the SIM card holder out of the top of the phone using your fingernail.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
Use the flat end of a spudger to disconnect the camera connectors.
Pull the camera up and out to remove it from the phone.
Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
Remove the orange flex cable from the phone.
Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
Remove the antenna.
Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
2 weitere Personen haben diese Anleitung absolviert.
