Zum Hauptinhalt wechseln
Nokia Lumia 930 Screen Replacement
Was du brauchst
  1. Nokia Lumia 930 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Screen Replacement: Schritt 2, Bild 1 von 2 Nokia Lumia 930 Screen Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Screen Replacement: Schritt 3, Bild 1 von 2 Nokia Lumia 930 Screen Replacement: Schritt 3, Bild 2 von 2
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Screen Replacement: Schritt 5, Bild 1 von 1
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Screen Replacement: Schritt 6, Bild 1 von 2 Nokia Lumia 930 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Screen Replacement: Schritt 7, Bild 1 von 3 Nokia Lumia 930 Screen Replacement: Schritt 7, Bild 2 von 3 Nokia Lumia 930 Screen Replacement: Schritt 7, Bild 3 von 3
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Screen Replacement: Schritt 8, Bild 1 von 1
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Screen Replacement: Schritt 9, Bild 1 von 1
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove the battery from the phone.
  11. Nokia Lumia 930 Screen Replacement, Motherboard: Schritt 11, Bild 1 von 2 Nokia Lumia 930 Screen Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the camera connectors.
    • Pull the camera up and out to remove it from the phone.
  12. Nokia Lumia 930 Screen Replacement: Schritt 12, Bild 1 von 1
    • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
  13. Nokia Lumia 930 Screen Replacement: Schritt 13, Bild 1 von 3 Nokia Lumia 930 Screen Replacement: Schritt 13, Bild 2 von 3 Nokia Lumia 930 Screen Replacement: Schritt 13, Bild 3 von 3
    • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
    • Remove the orange flex cable from the phone.
  14. Nokia Lumia 930 Screen Replacement: Schritt 14, Bild 1 von 1
    • Repeat the previous step for the black jumper flex cable under the battery.
  15. Nokia Lumia 930 Screen Replacement: Schritt 15, Bild 1 von 2 Nokia Lumia 930 Screen Replacement: Schritt 15, Bild 2 von 2
    • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
    • Remove the antenna.
  16. Nokia Lumia 930 Screen Replacement: Schritt 16, Bild 1 von 1
    • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
    • Apply new adhesive when reassembling the phone.
  17. Nokia Lumia 930 Screen Replacement: Schritt 17, Bild 1 von 3 Nokia Lumia 930 Screen Replacement: Schritt 17, Bild 2 von 3 Nokia Lumia 930 Screen Replacement: Schritt 17, Bild 3 von 3
    • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
  18. Nokia Lumia 930 Screen Replacement, Daughterboard: Schritt 18, Bild 1 von 2 Nokia Lumia 930 Screen Replacement, Daughterboard: Schritt 18, Bild 2 von 2
    • Use the pointed end of the spudger to pry up the daughterboard.
    • Use tweezers to lift the daughterboard out of the phone.
  19. Nokia Lumia 930 Screen Replacement, Display: Schritt 19, Bild 1 von 3 Nokia Lumia 930 Screen Replacement, Display: Schritt 19, Bild 2 von 3 Nokia Lumia 930 Screen Replacement, Display: Schritt 19, Bild 3 von 3
    • Place a suction cup in the center of the screen, then pry the display away from the frame.
    • When removing the display, pull slowly so that the flex cable does not become damaged.
    • Be sure to fold the display flex cable and ensure it is inserted safely when you are reassembling the display.
    • Remove any adhesive on the display and add new adhesive tape when reassembling the display.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 2,634
