Zum Hauptinhalt wechseln
Nokia N70 Speaker Replacement
Was du brauchst
  1. Nokia N70 Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the phone.
  5. Nokia N70 Speaker Replacement, Keypad: Schritt 5, Bild 1 von 3 Nokia N70 Speaker Replacement, Keypad: Schritt 5, Bild 2 von 3 Nokia N70 Speaker Replacement, Keypad: Schritt 5, Bild 3 von 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Speaker Replacement: Schritt 6, Bild 1 von 3 Nokia N70 Speaker Replacement: Schritt 6, Bild 2 von 3 Nokia N70 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Speaker Replacement, Speaker: Schritt 7, Bild 1 von 2 Nokia N70 Speaker Replacement, Speaker: Schritt 7, Bild 2 von 2
    • Use the T6 Torx screwdriver to remove the six 15 mm Torx screws.
  8. Nokia N70 Speaker Replacement: Schritt 8, Bild 1 von 3 Nokia N70 Speaker Replacement: Schritt 8, Bild 2 von 3 Nokia N70 Speaker Replacement: Schritt 8, Bild 3 von 3
    • Lift the bottom edge of the front panel at a 45 degree angle.
    • Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
  9. Nokia N70 Speaker Replacement: Schritt 9, Bild 1 von 3 Nokia N70 Speaker Replacement: Schritt 9, Bild 2 von 3 Nokia N70 Speaker Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Locate the speaker location located on the back panel of the phone.
    • Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located
    • Slowly lift speaker away from the back panel.
Abschluss
Justin
984 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-2, Regan Fall 2011 Mitglied von Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 4,165
