Zum Hauptinhalt wechseln
Nokia N900 Slider Assembly Replacement
Was du brauchst
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: Schritt 1, Bild 1 von 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 Slider Assembly Replacement: Schritt 2, Bild 1 von 2 Nokia N900 Slider Assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 Slider Assembly Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 Slider Assembly Replacement: Schritt 4, Bild 1 von 2 Nokia N900 Slider Assembly Replacement: Schritt 4, Bild 2 von 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 Slider Assembly Replacement: Schritt 5, Bild 1 von 1
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Troy Posey
349 Reputation
2 Anleitungen geschrieben
New Mexico State, Team 1-4, Easley Spring 2014 Mitglied von New Mexico State, Team 1-4, Easley Spring 2014
NMSU-EASLEY-S14S1G4
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 873
