Zum Hauptinhalt wechseln
Nokia N900 USB Replacement
Was du brauchst
  1. Nokia N900 USB Replacement, USB: Schritt 1, Bild 1 von 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: Schritt 2, Bild 1 von 2 Nokia N900 USB Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: Schritt 4, Bild 1 von 2 Nokia N900 USB Replacement: Schritt 4, Bild 2 von 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: Schritt 5, Bild 1 von 1
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: Schritt 6, Bild 1 von 1
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: Schritt 7, Bild 1 von 1
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: Schritt 8, Bild 1 von 1
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Troy Posey
349 Reputation
2 Anleitungen geschrieben
New Mexico State, Team 1-4, Easley Spring 2014 Mitglied von New Mexico State, Team 1-4, Easley Spring 2014
NMSU-EASLEY-S14S1G4
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 2,601
