Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back cover of the device by applying light pressure toward the outer rim and display.
    • Remove the back cover of the device by applying light pressure toward the outer rim and display.
  2. Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • The M2 screws are shown in red.
    • The M1 screws are shown in orange.
  3. Gently separate the display from the chassis.
    • Gently separate the display from the chassis.
    • Slowly spread the display and chassis until the inside of the device is reachable.
    • Do not pull apart.
    • Using the spudger tool, release the top flex ribbon from the light swap package.
Abschluss
Jose Maya
357 Reputation
2 Anleitungen geschrieben
IUPUI, Team S7-G7, Wilson Spring 2017 Mitglied von IUPUI, Team S7-G7, Wilson Spring 2017
IUPUI-WILSON-S17S7G7
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 12
