Einleitung
Is your Nokia X unable to connect to a USB charger? This guide will shows how to replace a faulty USB port.
Was du brauchst
Remove the back cover of the device by applying light pressure toward the outer rim and display.
Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
The M2 screws are shown in red.
The M1 screws are shown in orange.
Gently separate the display from the chassis.
Slowly spread the display and chassis until the inside of the device is reachable.
In diesem Schritt verwendetes Werkzeug:Spudger$2.99
Using the spudger tool, release the top flex ribbon from the light swap package.
Again, using a spudger tool, release the rear facing camera from the light swap display.
Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
Using a soldering iron, desolder they broken USB port.
Solder your replacement USB port onto the light swap package.
6 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
my mobile usb port no pls replacement
