Zum Hauptinhalt wechseln
Nokia XL Dual Sim Battery Replacement
Was du brauchst
  1. Nokia XL Dual Sim Battery Replacement, Replacing the battery: Schritt 1, Bild 1 von 3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: Schritt 1, Bild 2 von 3 Nokia XL Dual Sim Battery Replacement, Replacing the battery: Schritt 1, Bild 3 von 3
    • Shut off the device completely.
    • Separate the back cover from the device by gently prying the opening out at the loose locations.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
  2. Nokia XL Dual Sim Battery Replacement, Battery Removal: Schritt 2, Bild 1 von 2 Nokia XL Dual Sim Battery Replacement, Battery Removal: Schritt 2, Bild 2 von 2
    • Once the back cover is removed, the battery will be in plain sight.
    • Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
  3. Nokia XL Dual Sim Battery Replacement: Schritt 3, Bild 1 von 1
    • You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
    • Please be aware that your new battery may need to be charged first in order for your device to power back on.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Shadeed Bilal
231 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-4, Brown Fall 2014 Mitglied von USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 2,553
