Zum Hauptinhalt wechseln
Nokia XL Dual Sim Front Camera Replacement
Was du brauchst
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: Schritt 1, Bild 1 von 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: Schritt 2, Bild 1 von 2 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: Schritt 2, Bild 2 von 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: Schritt 3, Bild 1 von 2 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: Schritt 3, Bild 2 von 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: Schritt 4, Bild 1 von 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: Schritt 4, Bild 2 von 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Front Camera Replacement, System components: Schritt 5, Bild 1 von 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: Schritt 6, Bild 1 von 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: Schritt 6, Bild 2 von 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Shadeed Bilal
231 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-4, Brown Fall 2014 Mitglied von USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
merci 1000 fois pour ce cite
zmohye - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 1,088
