Zum Hauptinhalt wechseln
Noma Pedestal Fan Blade Replacement
Was du brauchst
  1. Noma Pedestal Fan Blade Replacement, Fan Blade: Schritt 1, Bild 1 von 2 Noma Pedestal Fan Blade Replacement, Fan Blade: Schritt 1, Bild 2 von 2
    • Undo the clips on the outer edge of the fan.
    • Make sure the fan is disconnected from the power source before starting.
  2. Noma Pedestal Fan Blade Replacement: Schritt 2, Bild 1 von 2 Noma Pedestal Fan Blade Replacement: Schritt 2, Bild 2 von 2
    • Gently remove the front piece by pulling it towards the bottom.
    • Don't pull too hard to avoid damaging the clips on the fan.
  3. Noma Pedestal Fan Blade Replacement: Schritt 3, Bild 1 von 1
    • Turn the cap clockwise and remove it.
  4. Noma Pedestal Fan Blade Replacement: Schritt 4, Bild 1 von 3 Noma Pedestal Fan Blade Replacement: Schritt 4, Bild 2 von 3 Noma Pedestal Fan Blade Replacement: Schritt 4, Bild 3 von 3
    • Lightly pull the faulty blade towards you.
    • Be careful while pulling to not injure yourself.
  5. Noma Pedestal Fan Blade Replacement: Schritt 5, Bild 1 von 2 Noma Pedestal Fan Blade Replacement: Schritt 5, Bild 2 von 2
    • Insert the new fan blade onto the screw .
    • Make sure it's pushed all the way back.
  6. Noma Pedestal Fan Blade Replacement: Schritt 6, Bild 1 von 2 Noma Pedestal Fan Blade Replacement: Schritt 6, Bild 2 von 2
    • Place the cap on the screw and tighten it by turning counterclockwise.
  7. Noma Pedestal Fan Blade Replacement: Schritt 7, Bild 1 von 2 Noma Pedestal Fan Blade Replacement: Schritt 7, Bild 2 von 2
    • After placing the front piece back on, fasten the clips again.
    • Make sure you align the piece to fit perfectly on the top.
Abschluss
This is a relatively easy process and as long as you follow our step-by-step guide it should be easy to fix.
Eine weitere Person hat diese Anleitung absolviert.
Taha Hashmi
172 Reputation
1 Anleitung geschrieben
York University, Team P-6, O'Regan Winter 2024 Mitglied von York University, Team P-6, O'Regan Winter 2024
YORK-O'REGAN-W24SPG6
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 366
