Zum Hauptinhalt wechseln
Nook Color Battery Replacement
Was du brauchst
  1. Nook Color Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nook Color Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Battery Replacement: Schritt 2, Bild 1 von 2 Nook Color Battery Replacement: Schritt 2, Bild 2 von 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Battery Replacement, Front Cover: Schritt 3, Bild 1 von 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Battery Replacement: Schritt 4, Bild 1 von 2 Nook Color Battery Replacement: Schritt 4, Bild 2 von 2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Battery Replacement: Schritt 5, Bild 1 von 2 Nook Color Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Battery Replacement, Battery: Schritt 6, Bild 1 von 2 Nook Color Battery Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the tape which holds the wiring to the battery using a plastic opening tool.
  7. Nook Color Battery Replacement: Schritt 7, Bild 1 von 3 Nook Color Battery Replacement: Schritt 7, Bild 2 von 3 Nook Color Battery Replacement: Schritt 7, Bild 3 von 3
    • On the back side of the middle panel, pry the battery using the plastic opening tools.
    • Use of force is necessary since the battery is glued down.
  8. Nook Color Battery Replacement: Schritt 8, Bild 1 von 2 Nook Color Battery Replacement: Schritt 8, Bild 2 von 2
    • Slide the connecting wire through the opening of where the battery was placed.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
John Goly
490 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 11-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 2,883
