Zum Hauptinhalt wechseln
Nook Color Display Replacement
Was du brauchst
    1. Nook Color Display Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nook Color Display Replacement, Back Cover: Schritt 1, Bild 2 von 2
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Nook Color Display Replacement: Schritt 2, Bild 1 von 2 Nook Color Display Replacement: Schritt 2, Bild 2 von 2
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      Frag FixBot
    1. Nook Color Display Replacement, Front Cover: Schritt 3, Bild 1 von 1
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      Frag FixBot
    2. Nook Color Display Replacement: Schritt 4, Bild 1 von 2 Nook Color Display Replacement: Schritt 4, Bild 2 von 2
      • Pry off the front panel using the plastic opening tool.
      Frag FixBot
    3. Nook Color Display Replacement: Schritt 5, Bild 1 von 2 Nook Color Display Replacement: Schritt 5, Bild 2 von 2
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      Frag FixBot
    1. Nook Color Display Replacement, Motherboard: Schritt 6, Bild 1 von 3 Nook Color Display Replacement, Motherboard: Schritt 6, Bild 2 von 3 Nook Color Display Replacement, Motherboard: Schritt 6, Bild 3 von 3
      • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
      Frag FixBot
    2. Nook Color Display Replacement: Schritt 7, Bild 1 von 1
      • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
      Frag FixBot
    3. Nook Color Display Replacement: Schritt 8, Bild 1 von 2 Nook Color Display Replacement: Schritt 8, Bild 2 von 2
      • Lift the motherboard gently from the side with the larger connector ribbon.
      • Slide the white cable gently from underneath its holding place to free the motherboard completely.
      • Remove the motherboard carefully from the device.
      Frag FixBot
    1. Nook Color Display Replacement, Display: Schritt 9, Bild 1 von 3 Nook Color Display Replacement, Display: Schritt 9, Bild 2 von 3 Nook Color Display Replacement, Display: Schritt 9, Bild 3 von 3
      • Use a plastic opening tool to gently pry the display upwards.
      • Lift the display out with your hands until the display has separated from the frame.
      Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 11-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Mitglieder
14 Anleitungen geschrieben
1 Kommentar zur Anleitung
this site doesn't sell the Nook Color display. Where did you get yours?
Suzette Garoutte - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 59
Insgesamt: 4,423
