Zum Hauptinhalt wechseln
Nook Color Speaker Replacement
Was du brauchst
  1. Nook Color Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nook Color Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Speaker Replacement: Schritt 2, Bild 1 von 2 Nook Color Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Speaker Replacement, Front Cover: Schritt 3, Bild 1 von 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Speaker Replacement: Schritt 4, Bild 1 von 2 Nook Color Speaker Replacement: Schritt 4, Bild 2 von 2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Speaker Replacement: Schritt 5, Bild 1 von 2 Nook Color Speaker Replacement: Schritt 5, Bild 2 von 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Speaker Replacement, Speaker: Schritt 6, Bild 1 von 2 Nook Color Speaker Replacement, Speaker: Schritt 6, Bild 2 von 2
    • Remove the protective lining located above the speaker.
  7. Nook Color Speaker Replacement: Schritt 7, Bild 1 von 3 Nook Color Speaker Replacement: Schritt 7, Bild 2 von 3 Nook Color Speaker Replacement: Schritt 7, Bild 3 von 3
    • Using a plastic opening tool, push on the speaker from the front of the panel to loosen the speaker. Some force will be required. Once loose, use your index finger to push it through.
  8. Nook Color Speaker Replacement: Schritt 8, Bild 1 von 1
    • Once pressed all the way through, the speaker will be loose and free to replace.
Abschluss
John Goly
508 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 11-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 321
