Zum Hauptinhalt wechseln
Nook HD+ Battery Replacement
Was du brauchst
  1. Nook HD+ Battery Replacement, Remove the front frame: Schritt 1, Bild 1 von 3 Nook HD+ Battery Replacement, Remove the front frame: Schritt 1, Bild 2 von 3 Nook HD+ Battery Replacement, Remove the front frame: Schritt 1, Bild 3 von 3
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: Schritt 2, Bild 1 von 2 Nook HD+ Battery Replacement, Remove the screws: Schritt 2, Bild 2 von 2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: Schritt 3, Bild 1 von 1
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: Schritt 4, Bild 1 von 3 Nook HD+ Battery Replacement, Detach battery: Schritt 4, Bild 2 von 3 Nook HD+ Battery Replacement, Detach battery: Schritt 4, Bild 3 von 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: Schritt 5, Bild 1 von 2 Nook HD+ Battery Replacement, Remove the battery: Schritt 5, Bild 2 von 2
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: Schritt 6, Bild 1 von 1
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Elijah Gonsalves
1.049 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Mitglieder
10 Anleitungen geschrieben
5 Kommentare
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Antwort
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Antwort
Anyone have a lead on good batteries?
omarhani - Antwort
clear directions, liked this guide
wandat100 - Antwort
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 46
Insgesamt: 9,504
