Zum Hauptinhalt wechseln
Einleitung
This replacement guide for the Nook HD+ requires the use of a soldering iron which should not be used by children, and if mishandled could lead to extreme injury.
  1. Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit. Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Carefully remove the center chassis from the bottom frame. Carefully remove the center chassis from the bottom frame.
    • Carefully remove the center chassis from the bottom frame.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard.
    • Detach the battery ribbon from the motherboard.
  6. Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  7. Remove the wire from the attachment on the motherboard (this wire un-clips). Remove the wire from the attachment on the motherboard (this wire un-clips).
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  8. Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten. Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  9. Replace new antenna following all the steps in reverse. Replace new antenna following all the steps in reverse.
    • Replace new antenna following all the steps in reverse.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Elijah Gonsalves
965 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 773
