Einleitung
This guide tells you how to replace the battery on the Nook HD+ from Barnes & Noble.
  1. Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook. Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook. Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit. Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Carefully remove center chassis from bottom frame.
    • Carefully remove center chassis from bottom frame.
  5. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard. Detach the battery ribbon from the motherboard.
    • Detach the battery ribbon from the motherboard.
  6. Pry battery off of bottom frame using plastic opening tool. Pry battery off of bottom frame using plastic opening tool.
    • Pry battery off of bottom frame using plastic opening tool.
  7. Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Elijah Gonsalves
914 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Mitglieder
5 Anleitungen geschrieben
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Antwort
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Antwort
Anyone have a lead on good batteries?
omarhani - Antwort
clear directions, liked this guide
wandat100 - Antwort
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 28
Letzte 30 Tage: 136
Insgesamt: 6,076
