Zum Hauptinhalt wechseln
Nook Simple Touch with GlowLight Battery Replacement
Was du brauchst
  1. Nook Simple Touch with GlowLight Battery Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Battery Replacement: Schritt 2, Bild 1 von 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Battery Replacement: Schritt 3, Bild 1 von 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Battery Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Battery Replacement: Schritt 5, Bild 1 von 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Battery Replacement, Battery: Schritt 6, Bild 1 von 2 Nook Simple Touch with GlowLight Battery Replacement, Battery: Schritt 6, Bild 2 von 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
Abschluss
Sean Blevins
73 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 44
Insgesamt: 1,030
