Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the midframe of your Nook Tablet. This guide is also a prerequisite for accessing or replacing most of the Nook's internal components.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the Nook over.
    • Flip the Nook over.
  2. Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present. Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Insert the flat end of a spudger between the front panel and the rear assembly. Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Slide the spudger around the edges of the Nook to loosen the back panel. Slide the spudger around the edges of the Nook to loosen the back panel.
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Pull the back panel off the Nook.
    • Pull the back panel off the Nook.
  6. Remove the ten T5 screws from around the edges of the silver midframe. Remove the ten T5 screws from around the edges of the silver midframe.
    • Remove the ten T5 screws from around the edges of the silver midframe.
  7. Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe. Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Lift up the foam pad at the corner of the battery to reveal the battery connector. Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Lift up the foam that covers the power connector and volume connector.
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Carefully lift the silver midframe away from the motherboard and display assembly. Carefully lift the silver midframe away from the motherboard and display assembly.
    • Carefully lift the silver midframe away from the motherboard and display assembly.
Abschluss
Holly Lowe
223 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 1-4, Propen Fall 2012 Mitglied von Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 215
