Zum Hauptinhalt wechseln
Nortel Networks i2004 IP Speaker Replacement
Was du brauchst
  1. Nortel Networks i2004 IP Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Speaker Replacement: Schritt 3, Bild 1 von 2 Nortel Networks i2004 IP Speaker Replacement: Schritt 3, Bild 2 von 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Speaker Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Speaker Replacement: Schritt 5, Bild 1 von 2 Nortel Networks i2004 IP Speaker Replacement: Schritt 5, Bild 2 von 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Speaker Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  7. Nortel Networks i2004 IP Speaker Replacement: Schritt 7, Bild 1 von 1
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  8. Nortel Networks i2004 IP Speaker Replacement: Schritt 8, Bild 1 von 2 Nortel Networks i2004 IP Speaker Replacement: Schritt 8, Bild 2 von 2
    • Solder wires to new speaker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Elizabeth
160 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-35, Amido Winter 2012 Mitglied von Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,123
