Zum Hauptinhalt wechseln
Nostalgia Electrics PCM805 Motor Replacement
Was du brauchst
  1. Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: Schritt 1, Bild 1 von 2 Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: Schritt 1, Bild 2 von 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Motor Replacement: Schritt 2, Bild 1 von 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: Schritt 3, Bild 1 von 2 Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: Schritt 3, Bild 2 von 2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  4. Nostalgia Electrics PCM805 Motor Replacement: Schritt 4, Bild 1 von 3 Nostalgia Electrics PCM805 Motor Replacement: Schritt 4, Bild 2 von 3 Nostalgia Electrics PCM805 Motor Replacement: Schritt 4, Bild 3 von 3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  5. Nostalgia Electrics PCM805 Motor Replacement, Motor: Schritt 5, Bild 1 von 2 Nostalgia Electrics PCM805 Motor Replacement, Motor: Schritt 5, Bild 2 von 2
    • Remove the four 12mm Phillips #02 screws to free the motor housing.
  6. Nostalgia Electrics PCM805 Motor Replacement: Schritt 6, Bild 1 von 2 Nostalgia Electrics PCM805 Motor Replacement: Schritt 6, Bild 2 von 2
    • Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
Abschluss
USF Tampa, Team 3-5, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
Moh - Antwort
Hi, I need the cotton machine from the nostalgia cotton sugar machine and I don't know where to get it. can you help me? My email is terebcn18@hotmail.com
Teresa gb - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 35
Insgesamt: 3,139
