Einleitung
This guide will outline how to replace the fan inside the heating component.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Flip the popper on its side.
Remove the screws on the bottom with the Phillips #2 phillips head screwdriver.
Remove the base.
Unscrew the two screws (10 mm Philips #2 screws) from the base.
Remove the base and set it aside for now.
Locate the power switch connected to the side of the housing.
Carefully pinch the sides of the power switch.
Push the power button up and out of the housing.
Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
Use the plastic opening tool to gently pry the wires loose from the power switch.
Remove the power switch from the device.
You can now replace the power switch if necessary.
Now that the power switch is disconnected from the popper, you will need to remove the white top.
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Now that the white top is disconnected from the housing, remove the heating component from inside the device.
Unscrew the three screws (10 mm Philips #2 screws) that hold the heating component together.
