Einleitung
This guide will show you how to replace the heating bowl.
Was du brauchst
Remove the two 1.3 mm Phillips #2 screws.
Remove the S6 spanner screw.
Split the device in half to expose the internal parts of the device.
Again, there are two more Phillips screws to remove.
Follow the instruction and you will know how to replace the bowl for this device
3 weitere Nutzer:innen haben diese Anleitung absolviert.
