Einleitung
This is a replacement guide that teaches you how to replce power cable for Nostalgia GCM-200.
Was du brauchst
Remove the two 1.3 mm Phillips #2 screws.
Remove the S6 spanner screw.
Split the device in half to expose the internal parts of the device.
Again, there are two more Phillips screws to remove.
Remove (flexible) plastic sleeves from the inside end of the power cable.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
