Zum Hauptinhalt wechseln
Novatel MiFi 2 4G LTE Hotspot SIM Card Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: Schritt 1, Bild 1 von 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: Schritt 1, Bild 2 von 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: Schritt 1, Bild 3 von 3
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Place your thumb under the latch of the black plastic battery cover as shown.
    • Remove the battery cover. This will require some force.
  2. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery: Schritt 2, Bild 1 von 2 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery: Schritt 2, Bild 2 von 2
    • Gently place your thumb on the right side of the battery as shown.
    • Remove the battery from its socket by lifting it up and out.
  3. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: Schritt 3, Bild 1 von 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: Schritt 3, Bild 2 von 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: Schritt 3, Bild 3 von 3
    • Once the battery has been removed, the SIM Card slot can be accessed.
    • Carefully take out the dead SIM Card by lifting it from its position with your fingers.
Abschluss
GerardFoley
351 Reputation
4 Anleitungen geschrieben
Marist, Team S1-G5, Chaterdon Fall 2018 Mitglied von Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
3 Mitglieder
Ein Kommentar
What kind of SIM card do I need for this?
Abner - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 727
