Einleitung
Splitting the case of the Mifi 2200 is necessary to be able access the internal parts. This is how to go about that.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the rear cover by pressing down on the cover and pulling it away from the device.
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Place your finger on the back of the battery located near the edge of the device.
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Using a metal spudger, pry open the device around the seam between the front and back cover.
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  5. Once the seal has been broken all the way around, open the cases using your hands.
    • Once the seal has been broken all the way around, open the cases using your hands.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Justin Russo
196 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-36, Maness Spring 2012 Mitglied von Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Mitglieder
5 Anleitungen geschrieben
If case gets damaged, is there a place to but the case
Snehraj Merchant - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,376
