Zum Hauptinhalt wechseln
Novatel MiFi 2200 Case Replacement
Was du brauchst
  1. Novatel MiFi 2200 Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: Schritt 2, Bild 1 von 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: Schritt 3, Bild 1 von 1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: Schritt 4, Bild 1 von 1
    • Once the seal has been broken all the way around, open the cases using your hands.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Justin Russo
196 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-36, Maness Spring 2012 Mitglied von Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
If case gets damaged, is there a place to but the case
Snehraj Merchant - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,529
