Einleitung
How to access and replace the motherboard. Be careful when taking off the back cover and make sure to carefully unplug all wires.
Was du brauchst
Turn the device screen side down.
Carefully remove the back piece with the iFixit opening tool.
Pull the camera plug upward and away from the motherboard with your fingers.
Gently pull the camera from the device. The camera is held by tension.
Remove speakers gently using your fingers, they pop out easily.
Disconnect cords attached to the speaker from white pod.
Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
Disconnect the battery's bundled cable connector from the motherboard with fingers.
Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
