Einleitung
This guide will show you how to replace a motherboard. Replacing the motherboard will require frequent soldering.
Was du brauchst
Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
Remove the two plugs for the screen by pulling up and away from the motherboard.
Remove the plug for the cameras by pulling the plug up and away from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
