Einleitung
Your time will be split between removing the back from the device and de-soldering. The charging port itself is actually soldered onto the bottom of the motherboard. To access it, it is best to remove the motherboard from the device.
Was du brauchst
Use a Heat Gun to loosen the adhesive on the underside of the back cover.
Use some prying tools to lift the back cover off of the device.
Desolder the Motherboard- this will make it easier to get to the charging port without breaking any cords.
Flip the Motherboard over and desolder the charging port from Motherboard.
