Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Most of your time will be getting the back off of the device. The cameras are held down with a little adhesive but are relatively easy to remove.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a Heat Gun to heat the sides of the device one at a time.  The Heat Gun will loosen the adhesive. Use thin tools to pry the back of the device off.
    • Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
    • Use thin tools to pry the back of the device off.
    • Metal tools may work best but may also scratch the device. Plastic prying tools can also be used.
    • Be careful around the power and volume buttons.
  2. There are two different cameras and each have different ribbons.
    • There are two different cameras and each have different ribbons.
    • Unlock both ribbons by flipping the black bar up.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. The camera facing towards the table lifts out easily, so go ahead and take that one out. This works out well, if this is the camera you are most concerned about.
    • The camera facing towards the table lifts out easily, so go ahead and take that one out.
    • This works out well, if this is the camera you are most concerned about.
    • If you are more concerned the one facing you, move on to the next step.
  5. This camera is held down with adhesive, so you must be careful when prying it. GO SLOW!
    • This camera is held down with adhesive, so you must be careful when prying it.
    • GO SLOW!
    • Camera pulls up and out of its slot easily.
Abschluss
Be advised that you will need to replace the adhesive.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 249
