Zum Hauptinhalt wechseln
Numark TT1600 Belt Drive Replacement
  1. Numark TT1600 Belt Drive Replacement, Belt Drive: Schritt 1, Bild 1 von 1
    • Remove slip mat from top of the platter.
  2. Numark TT1600 Belt Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
  3. Numark TT1600 Belt Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove damaged belt which will be located below the platter.
  4. Numark TT1600 Belt Drive Replacement: Schritt 4, Bild 1 von 1
    • Install new belt by securing it around the inner ring, located on the back of the platter.
  5. Numark TT1600 Belt Drive Replacement: Schritt 5, Bild 1 von 1
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
  6. Numark TT1600 Belt Drive Replacement: Schritt 6, Bild 1 von 2 Numark TT1600 Belt Drive Replacement: Schritt 6, Bild 2 von 2
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
  7. Numark TT1600 Belt Drive Replacement: Schritt 7, Bild 1 von 1
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nikolai
254 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 17-14, Regan Fall 2011 Mitglied von Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 45
Insgesamt: 6,288
