Zum Hauptinhalt wechseln
Numark TT1600 Tone Arm Replacement
Was du brauchst
  1. Numark TT1600 Tone Arm Replacement, Tone Arm: Schritt 1, Bild 1 von 2 Numark TT1600 Tone Arm Replacement, Tone Arm: Schritt 1, Bild 2 von 2
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Numark TT1600 Tone Arm Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by pulling it apart.
  3. Numark TT1600 Tone Arm Replacement: Schritt 3, Bild 1 von 3 Numark TT1600 Tone Arm Replacement: Schritt 3, Bild 2 von 3 Numark TT1600 Tone Arm Replacement: Schritt 3, Bild 3 von 3
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Numark TT1600 Tone Arm Replacement: Schritt 4, Bild 1 von 3 Numark TT1600 Tone Arm Replacement: Schritt 4, Bild 2 von 3 Numark TT1600 Tone Arm Replacement: Schritt 4, Bild 3 von 3
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Numark TT1600 Tone Arm Replacement: Schritt 5, Bild 1 von 2 Numark TT1600 Tone Arm Replacement: Schritt 5, Bild 2 von 2
    • Gently pull the wire that you just unscrewed to release it from the clip.
  6. Numark TT1600 Tone Arm Replacement: Schritt 6, Bild 1 von 3 Numark TT1600 Tone Arm Replacement: Schritt 6, Bild 2 von 3 Numark TT1600 Tone Arm Replacement: Schritt 6, Bild 3 von 3
    • Remove the two screws connecting the circuit board to the tone arm.
  7. Numark TT1600 Tone Arm Replacement: Schritt 7, Bild 1 von 2 Numark TT1600 Tone Arm Replacement: Schritt 7, Bild 2 von 2
    • Remove the two remaining screws connecting the tone arm to the device.
  8. Numark TT1600 Tone Arm Replacement: Schritt 8, Bild 1 von 1
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  9. Numark TT1600 Tone Arm Replacement: Schritt 9, Bild 1 von 3 Numark TT1600 Tone Arm Replacement: Schritt 9, Bild 2 von 3 Numark TT1600 Tone Arm Replacement: Schritt 9, Bild 3 von 3
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  10. Numark TT1600 Tone Arm Replacement: Schritt 10, Bild 1 von 3 Numark TT1600 Tone Arm Replacement: Schritt 10, Bild 2 von 3 Numark TT1600 Tone Arm Replacement: Schritt 10, Bild 3 von 3
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nikolai
254 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 17-14, Regan Fall 2011 Mitglied von Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 8,211
