Zum Hauptinhalt wechseln
Nutri Ninja Ninja Blender Duo BL641 Blade Replacement
Was du brauchst
  1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: Schritt 1, Bild 1 von 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: Schritt 1, Bild 2 von 2
    • Make sure blender is turned off.
    • Lift open the lid of blender by pressing the "Release" button and move to the side
  2. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: Schritt 2, Bild 1 von 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: Schritt 2, Bild 2 von 2
    • Carefully Grab the top of the blade and pull upward with medium force.
    • The blade should slide out easily.
    • Do not touch the blades! Even when dull they can still cut you.
  3. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: Schritt 3, Bild 1 von 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: Schritt 3, Bild 2 von 2
    • Carefully pick up the new blade and match the bottom star shaped opening to the star shaped protrusion from the blender.
  4. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: Schritt 4, Bild 1 von 1
    • Slowly connect the two star shapes together and push down until it reaches the bottom.
Abschluss
Now your blender can resume blending to perfection.
Charlotte
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team S7-G1, Banghart Fall 2017 Mitglied von Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 3,203
