Zum Hauptinhalt wechseln
Nutribullet Rx #NB-301 Drive Socket Replacement
Was du brauchst
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: Schritt 1, Bild 1 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: Schritt 1, Bild 2 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: Schritt 1, Bild 3 von 3
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 2, Bild 1 von 2 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 2, Bild 2 von 2
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 3, Bild 1 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 3, Bild 2 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 3, Bild 3 von 3
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 4, Bild 1 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 4, Bild 2 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 4, Bild 3 von 3
    • Remove the drive socket from the motor.
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 5, Bild 1 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 5, Bild 2 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 5, Bild 3 von 3
    • Remove all dust and residue from the area before you replace your new drive socket.
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 6, Bild 1 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 6, Bild 2 von 3 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 7, Bild 1 von 2 Nutribullet Rx #NB-301 Drive Socket Replacement: Schritt 7, Bild 2 von 2
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
Abschluss
Martin G
145 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 7-3, Grodsky Spring 2024 Mitglied von CSU Los Angeles, Team 7-3, Grodsky Spring 2024
CSULA-GRODSKY-S24S7G3
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 52
Insgesamt: 77
