Einleitung
Be aware that most of your time will be spent getting the back off of the device. However, once in the device the repair is quick and easy.
Was du brauchst
Use a Heat Gun to loosen the adhesive around the inside of the device.
Use prying tools to lift the back of the device up.
Move the wires out of the way and slowly pull the ribbon out of the circuit dock.
Fast fertig!
Abschluss
