Zum Hauptinhalt wechseln
Nuvision TM800A510L Headphone Jack Replacement
Was du brauchst
  1. Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 2 Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 2 von 2
    • Use a Heat Gun to loosen the adhesive around the inside of the device.
    • Use prying tools to lift the back of the device up.
    • I recommend prying up one side at a time and heating the adhesive to 'just barely too hot to touch'.
  2. Nuvision TM800A510L Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the headphone jack from the device.
  3. Nuvision TM800A510L Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Unlock the headphone jack ribbon.
  4. Nuvision TM800A510L Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Move the wires out of the way and slowly pull the ribbon out of the circuit dock.
  5. Nuvision TM800A510L Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Lift headphone jack/ribbon out and it's FREE!
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 276
