Zum Hauptinhalt wechseln
Nuwave Brio 6Q Air Fryer Disassembly
    • There are 2 screws inside the cooking chamber.
  1. Nuwave Brio 6Q Air Fryer Disassembly, Popping Out the Clips: Schritt 2, Bild 1 von 3 Nuwave Brio 6Q Air Fryer Disassembly, Popping Out the Clips: Schritt 2, Bild 2 von 3 Nuwave Brio 6Q Air Fryer Disassembly, Popping Out the Clips: Schritt 2, Bild 3 von 3
    • The top will pop off at these clips, use a tool or your fingers to gently pull.
  2. Nuwave Brio 6Q Air Fryer Disassembly, Remove the Circuit Board: Schritt 3, Bild 1 von 2 Nuwave Brio 6Q Air Fryer Disassembly, Remove the Circuit Board: Schritt 3, Bild 2 von 2
    • Remove the screws to remove the circuit board.
    • The safety switch is what was bad on this one. I replaced it with one from eBay.
Abschluss
Jeff Miller
206 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 173
