Einleitung
バッテリーはデバイスの中でとても大きな面積を占めています。バッテリーは強めに接着されているので取り外す際は二次被害が発生しない様に注意が必要です。
Was du brauchst
タブレット外周の溝に青いプラスチック製開口ツールを差し込み、丁寧にバックパネルを少しずつ持ち上げます。Micro SDスロットの辺りから始めてください。
組み立て直す時は逆の順序で組み立てて下さい
15 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
7 Kommentare
Cannot find a replacement battery anywhere, any information would be appreciated.
Thanks!
Carl
Here: to aliexpress
I just happened to be looking because my battery life is atrocious. And here's the forum where I found it. They have other links too if you want to try them out.
I just happened to be looking into this myself. I found a forum with many links that can be found by searching “Finding Replacement Battery in 2017?” . The thread is on XDA-developers.com. This is a link that works: on de.aliexpress.com
Good luck. As there is no convincing upgrade from the Shield K1, I might do this too. Other people noted that you need the little PCB attached to the original battery to solder it onto the bare replacement battery.
