Zum Hauptinhalt wechseln
Nvidia Shield Display Assembly Replacement
Was du brauchst
  1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: Schritt 1, Bild 1 von 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: Schritt 1, Bild 2 von 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: Schritt 1, Bild 3 von 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: Schritt 2, Bild 1 von 2 Nvidia Shield Display Assembly Replacement, Remove Green Grill: Schritt 2, Bild 2 von 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: Schritt 3, Bild 1 von 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: Schritt 3, Bild 2 von 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: Schritt 3, Bild 3 von 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: Schritt 4, Bild 1 von 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Display Assembly Replacement, Removing Fan: Schritt 5, Bild 1 von 3 Nvidia Shield Display Assembly Replacement, Removing Fan: Schritt 5, Bild 2 von 3 Nvidia Shield Display Assembly Replacement, Removing Fan: Schritt 5, Bild 3 von 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: Schritt 6, Bild 1 von 1
    • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
    • Once removed, the display should be able to be detached.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Hickman Fall 2014 Mitglied von USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
Where can o get a replacement screen
jorge valenzuela - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 8
Letzten 30 Tage: 25
Insgesamt: 6,255
