Zum Hauptinhalt wechseln
Nvidia Shield Pro Android TV Bottom Cover Replacement
Was du brauchst
  1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Abschluss
Cal Poly, Team S18-G2, White Winter 2020 Mitglied von Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Hi, Shield Pro 2.
Remove 2 small cross head screws securing top cover to the back plate. Next you have to pry open the back edge and then slide the top cover forwards about 8mm away from the back plate to clear 3 catch points along each side.
S. Carter - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 23
Letzte 30 Tage: 102
Insgesamt: 2,259
