Zum Hauptinhalt wechseln
Nvidia Shield Pro Android TV Controller D-Pad Replacement
Was du brauchst
  1. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: Schritt 1, Bild 1 von 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: Schritt 1, Bild 2 von 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: Schritt 1, Bild 3 von 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 2, Bild 1 von 1
    • Gently open the top frame of the cover with the plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 3, Bild 1 von 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 3, Bild 2 von 2
    • Gently pull the wire connector out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 4, Bild 1 von 1
    • Remove the wire attached to the circular piece.
  5. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 5, Bild 1 von 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the two T6 Torx screws from either side of the motherboard.
  6. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 6, Bild 1 von 1
    • Remove the yellow plug from its socket.
  7. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 7, Bild 1 von 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 7, Bild 2 von 2
    • Remove the two T6 Torx screws.
  8. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 8, Bild 1 von 1
    • Slowly pull up the primary circuit board of the controller until the D-pad is revealed.
    • Carefully remove the board.
  9. Nvidia Shield Pro Android TV Controller D-Pad Replacement: Schritt 9, Bild 1 von 1
    • Gently remove and replace the D-Pad.
Abschluss
Ben Carrasco
347 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S18-G2, White Winter 2020 Mitglied von Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 52
Letzte 30 Tage: 92
Insgesamt: 1,517
