Zum Hauptinhalt wechseln
Nvidia Shield Pro Android TV Controller Motherboard Replacement
Was du brauchst
  1. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: Schritt 1, Bild 1 von 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: Schritt 1, Bild 2 von 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: Schritt 1, Bild 3 von 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 3, Bild 1 von 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 4, Bild 1 von 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 5, Bild 1 von 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: Schritt 6, Bild 1 von 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: Schritt 6, Bild 2 von 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: Schritt 6, Bild 3 von 3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 7, Bild 1 von 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 7, Bild 2 von 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
  8. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Controller Motherboard: Schritt 8, Bild 1 von 1
    • After removing the triggers, your motherboard is completely separate and ready to be replaced.
Abschluss
Your motherboard is ready to be replaced.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 313
