Was du brauchst
Remove the six T6 Torx screws from the back of the controller.
Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
Remove the guard piece that secures the thumb-sticks to the controller.
Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
Grip the plugs as close to their ports as possible and pull them directly up and out.
Lift the rumble motors up and out of the chassis.
