Zum Hauptinhalt wechseln
Nvidia Shield Pro Android TV Fan/Heat Sink Replacement
Was du brauchst
  1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: Schritt 2, Bild 1 von 3 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: Schritt 2, Bild 2 von 3 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: Schritt 2, Bild 3 von 3
    • Remove the five screws with a T6 Torx screwdriver.
    • Two of the screws are located directly on top of the fan/heat sink. The other three screws are located on a small triangle plate on the left side of the fan/heat sink.
  3. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: Schritt 3, Bild 1 von 2 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: Schritt 3, Bild 2 von 2
    • Once the screws are removed, gently detach the multi-colored wired connection from the motherboard.
  4. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the fan/heat sink out of the Nvidia Shield.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jimmy Chen
615 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S18-G2, White Winter 2020 Mitglied von Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Hello can you tell me where to buy the fan and the plastic case opener?
Sajid Idrees - Antwort
My version had screws in the back which I had to remove, and then I could simply slide it away from the ports in the back to open it. The inside was completely different as well, but it's a pretty simple device.
John Doe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 35
Letzte 30 Tage: 165
Insgesamt: 8,650
