Zum Hauptinhalt wechseln
Nvidia Shield Pro Android TV I/O Board Replacement
Was du brauchst
  1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: Schritt 2, Bild 1 von 3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: Schritt 2, Bild 2 von 3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: Schritt 2, Bild 3 von 3
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
  3. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 3, Bild 1 von 3 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 3, Bild 2 von 3 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 3, Bild 3 von 3
    • Detach the pack of wires by pulling it away from the socket.
  4. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 4, Bild 1 von 3 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 4, Bild 2 von 3 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 4, Bild 3 von 3
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
  5. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 5, Bild 1 von 2 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
  6. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the hard drive out of the device.
  7. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: Schritt 7, Bild 1 von 3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: Schritt 7, Bild 2 von 3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: Schritt 7, Bild 3 von 3
    • Detach the brown side of the connector from the I/O board by pulling it upward.
    • Remove the screw from the silver plate using a T6 Torx screwdriver.
    • Put the cable aside after removing it.
  8. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 8, Bild 1 von 2 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 8, Bild 2 von 2
    • Detach the small bundle of black wires from the I/O board by gently pulling upward.
    • Be very gentle because the wires are very fragile.
  9. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 9, Bild 1 von 2 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 9, Bild 2 von 2
    • Remove the three T6 Torx screws from the I/O board.
  10. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 10, Bild 1 von 3 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 10, Bild 2 von 3 Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 10, Bild 3 von 3
    • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
  11. Nvidia Shield Pro Android TV I/O Board Replacement: Schritt 11, Bild 1 von 1
    • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Jimmy Chen
615 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S18-G2, White Winter 2020 Mitglied von Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - Antwort
Aniyone managed to get a source for this part, The IO board
Yoda Mann - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 82
Insgesamt: 4,737
