Zum Hauptinhalt wechseln
Nvidia Shield Pro Android TV Motherboard Replacement
Was du brauchst
  1. Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Use a plastic opening tool to pry open the front panel.
  2. Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 2, Bild 1 von 3 Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 2, Bild 2 von 3 Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use a Torx TR6 screwdriver to remove the five 6mm screws that are securing the fan.
    • Unplug the power supply connected to the fan.
  3. Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 3, Bild 1 von 2 Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Unplug the two black cable bundles that are running over the motherboard.
  4. Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 4, Bild 1 von 3 Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 4, Bild 2 von 3 Nvidia Shield Pro Android TV Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a Torx TR6 screwdriver to remove the three 5mm screws securing the motherboard.
    • Detach the black and white coaxial cables from the motherboard.
    • Lift the motherboard out of the device and disconnect the black cable bundle.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Please update the title of this to specify which model year Shield Pro it is for. I was looking for the 2019 model instructions and this obviously isn't that.
Thanks!
jkr4m3r - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 20
Letzte 30 Tage: 62
Insgesamt: 2,559
