Einleitung
The heat sink will need to be replaced if your device consistently becomes very hot. Before removing the heat sink, make sure the device is turned off and is cool. When removing the component, make sure to be careful, as the parts are delicate and can break or chip easily.
Was du brauchst
Flip the device over and use a plastic opening tool to remove the bottom cover.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Or blindly buy a new one :D
