Einleitung
A camera lens on any device is naturally exposed to the elements of nature to obtain the clearest photo; however, this leaves the lens susceptible to damage and cracking. Cameras are used extremely frequently, especially on a device as portable as the Nvidia Shield Tablet. Follow this guide to replace both cameras on your tablet.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Set the tablet so the buttons, microSD, and stylus port are facing you.
Open the microSD slot.
Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
As you remove your case, be aware of small clips along the edges.
Finally, set the old casing aside.
Orient your tablet so that the top of the tablet is furthest away from you.
Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
Gently pry the speaker up with the flat end of a spudger.
Use a plastic opening tool to peel up the tape covering the speaker wire.
Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
Finally, unplug the power source from your speaker using the precision tweezers.
Having removed the speaker, locate the front-facing camera resting just underneath the speaker.
The rear-facing camera is on the left side of the tablet and it aligns with the camera hole on the back casing of your tablet.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Gently unplug each camera using the precision tweezers.
Eine weitere Person hat diese Anleitung absolviert.
