Zum Hauptinhalt wechseln
Nvidia Shield Tablet K1 Speaker Replacement
Was du brauchst
  1. Nvidia Shield Tablet K1 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Speaker Replacement: Schritt 2, Bild 1 von 2 Nvidia Shield Tablet K1 Speaker Replacement: Schritt 2, Bild 2 von 2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
  3. Nvidia Shield Tablet K1 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 3 Nvidia Shield Tablet K1 Speaker Replacement, Speaker: Schritt 3, Bild 2 von 3 Nvidia Shield Tablet K1 Speaker Replacement, Speaker: Schritt 3, Bild 3 von 3
    • Be careful when removing the two pieces of tape because there are wires underneath the tape. Lifting too hard may accidentally rip out the wires.
    • While using the black plastic spudger tool, slowly lift the tape with your fingers and hold the wires down with the tool.
  4. Nvidia Shield Tablet K1 Speaker Replacement: Schritt 4, Bild 1 von 2 Nvidia Shield Tablet K1 Speaker Replacement: Schritt 4, Bild 2 von 2
    • The audio input film is running underneath the foam piece and is fragile Be careful when removing this piece.
    • Slowly lift the black foam piece near the WIFI antenna to reveal the audio input film.
    • It is not necessary to remove the foam piece from the device entirely, just as long as you're able to free the audio input film without resistance.
  5. Nvidia Shield Tablet K1 Speaker Replacement: Schritt 5, Bild 1 von 3 Nvidia Shield Tablet K1 Speaker Replacement: Schritt 5, Bild 2 von 3 Nvidia Shield Tablet K1 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Carefully remove the audio input films for each speaker from their respective ZIF (zero insertion force) connectors. These are the paper thin ribbons that have orange stripes along them.
    • Pull up the white latch on the ZIF connector, which will release the film and allow you to pull it out with tweezers.
    • Repeat this for both speakers.
  6. Nvidia Shield Tablet K1 Speaker Replacement: Schritt 6, Bild 1 von 2 Nvidia Shield Tablet K1 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Remove the power cables connecting the speakers to the battery. These are black wires with gold tips.
    • Again, use the tweezers to carefully pull them up from their places, they should pop right off.
    • There are three of these black wires in total, but only two belong to the speakers. follow the paths of the wires to make sure they are connected to a speaker.
  7. Nvidia Shield Tablet K1 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Free the speakers by removing their screws. You'll need the J000 Phillips-head screw Driver.
    • Each screw is roughly 30 mm in length and 30 mm in diameter.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 7-7, Cagle Spring 2016 Mitglied von USF Tampa, Team 7-7, Cagle Spring 2016
USFT-CAGLE-S16S7G7
3 Mitglieder
9 Anleitungen geschrieben
3 Kommentare
Great tutorial!
Any idea where to buy the speakers as Nvidia does not sells them? (need the bottom one as it went (half) broken when i drilled a hole to fit the stylus inside the K1 version. Stylus does fit perfectly with a little drilling only the wire got damaged so the sound is lower then it should)
Anyway,
Thanks
and thanks!
Ferryvb - Antwort
Unfortunately, through our research we did not find anywhere for replacement parts. I would suggest ebay or other sites for ones that maybe already damaged and the speakers are still in working order. Sorry we couldnt help.
Ryan Butler -
I am wondering what type of connecter's thoes are attaching the wire's to the pcb.
Justin Mosimann - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 2,356
