Zum Hauptinhalt wechseln
Nvidia Shield Tablet K1 WIFI Antenna Replacement
Was du brauchst
  1. Nvidia Shield Tablet K1 WIFI Antenna Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 WIFI Antenna Replacement: Schritt 2, Bild 1 von 2 Nvidia Shield Tablet K1 WIFI Antenna Replacement: Schritt 2, Bild 2 von 2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
  3. Nvidia Shield Tablet K1 WIFI Antenna Replacement, WIFI Antenna: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
    • Make sure you disconnect the right cables. There are three of these.
  4. Nvidia Shield Tablet K1 WIFI Antenna Replacement: Schritt 4, Bild 1 von 1
    • Remove the screw adjacent to the WIFI Antenna using the J000 Philips head screw-driver.
    • Screw description: short black screw 20 mm length and 30 mm diameter.
  5. Nvidia Shield Tablet K1 WIFI Antenna Replacement: Schritt 5, Bild 1 von 1
    • Using the angled tweezers, begin removing the antenna from the device.
  6. Nvidia Shield Tablet K1 WIFI Antenna Replacement: Schritt 6, Bild 1 von 2 Nvidia Shield Tablet K1 WIFI Antenna Replacement: Schritt 6, Bild 2 von 2
    • The black plastic piece of the antenna is attached to a copper colored film which can be pulled up using the tweezers.
    • The antenna should now be free from the device.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 7-7, Cagle Spring 2016 Mitglied von USF Tampa, Team 7-7, Cagle Spring 2016
USFT-CAGLE-S16S7G7
3 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Odd question for you. I'm replacing the antena in a nvidia shield as an experimant, as was wonder if you know what type of connecter is used on the cable to the pcb. I dont want to desoder the exsisting antenna if i can help it as they are calabrated.
Justin Mosimann - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 5,107
